Activity › Forums › Apple Final Cut Pro Legacy › Unable to save in FCP 5.0.2
  • Unable to save in FCP 5.0.2
    Posted by Neil Harris on September 15, 2005 at 9:10 am
    hi,
    I’m occaisonally getting an error message that reads ‘Error Unknown File’ when attempting to save. I then cannot save my project and have to rebuild from the last successfull save point. This version was recently installed and i was first getting the problem if i copied a clip from one timeline to another. A software update fixed this – but now the problem has returned… Anyone else have this or a solution? I am fully updated now…
    (I’m usually saving to a SAN if that matters)
    Neil
    David Rowan replied 21 years ago 3 Members · 2 Replies
  • Walter Biscardi
    September 15, 2005 at 11:51 am
    Believe it or not, this has to do with your Still Memory Cache. I don’t know why, but if you up the Still Memory Cache to at least 30%, that error should go away.
    I have 4GB RAM and I upped it to 50% and the error went away (default is 10%). Definitely a bug in the program and I guess it wasn’t fixed with 5.0.2.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • David Rowan
    September 15, 2005 at 12:59 pm
    I had a similar problem on FCP 4.5. In my case it was some sort of disk problem.
    I discovered I could save the projects to other drives, so I saved it on my media drive, then I ran disk utilities (rebuild permisions) on the primary drive where I save my projects. After that things worked.
    DWR
