Activity › Forums › Adobe After Effects › Unable to render Video – Renders only 4 seconds or so from a 4 minute video.
  • Unable to render Video – Renders only 4 seconds or so from a 4 minute video.
    Posted by Denis Sec on August 14, 2020 at 7:05 am
    Hello,
    I’m quite new to After effects, after playing around with it for a bit and watching a few tutorials i decided to render my first video. I am using a render server with;
    – 128gb ram
    – gtx 1080
    – ssd drives
    using Deadline to render it. ( AE 2020 )
    When i go through the process to render it, for some reason it only renders a couple of seconds & not the whole videos. I’ve tried mutliple settings & have googled for hours with no luck so this is my last hope. Screenshots below for my timeline etc. Any help would be greatly appreciated.
    Denis Sec replied 6 years, 1 month ago 3 Members · 4 Replies
  • John Cuevas
    August 14, 2020 at 2:10 pm
    Are you getting any errors after you render. Does the 4 second video play or is it corrupted?
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Richard Garabedain
    August 14, 2020 at 3:35 pm
    Render it out using a png sequence first…then see where it fails at. where ever it fails at there is an effect or something going on there. Motion tile will usually do it if the settings are too high
  • Denis Sec
    August 15, 2020 at 5:40 am
    I do get a few errors pop up when rendering, either quicktime or AVI etc. ( Pastbin link below ) The video the does render is usually around 4 seconds 99% of the time but it sometimes starts at the begining, sometimes halfway through or sometimes near the end.
    The pastebin link shows the 2 errors of the most recent test.
    https://pastebin.com/whnRM8Yv
    https://pastebin.com/a5d1sGLE
  • Denis Sec
    August 15, 2020 at 5:42 am
    I did a render with PNG only, normally when i do the renders using quicktime / avi it only takes couple minutes ( about 5 – 10 minutes ) PNG took about 1hr30 minutes and no errors appeared, everything seemed to have worked fine.
    Screenshot attached of the PNG test & running a test straight after using the Quicktime Animation format.
