Activity › Forums › Apple Final Cut Pro Legacy › Unable to Play a QT File on New Macs
  • Unable to Play a QT File on New Macs
    Posted by Thomas Hughes on October 11, 2011 at 6:39 pm
    I just finished cutting a program for a client on FC. It’s a twelve minute program, a 3.5G file. I put it as a QT file on a USB flash drive. He just loaded it to his brand new Mac and it gave us this error message, The document “Branson Admissions Video 2011.mov” could not be opened. The movie is not in a format that QuickTime Player understands.
    You may need to install additional software to open this type of file.
    We also tried it on a brand new MacBook Pro.
    It loads to our Macs and plays fine. The only difference I can see is that our Macs are older. Also, our Macs have FC on them, his doesn’t. Does that make any difference?
    What do I need to do to get this to load and play on his Mac? tx
    Thomas H
    Thomas Hughes replied 14 years, 11 months ago 6 Members · 12 Replies
  • 12 Replies
  • Neil Patience
    October 11, 2011 at 6:46 pm
    The reason is that without FCP you do not have all codecs available, PRORES for example comes with FCP and will not play as standard.
    So you need to export in something that is standard in QuickTime. H264 for example or any of the Apple Tv export settings will work.
    best wishes
    Neil
    http://www.patience.tv
  • David Roth weiss
    [Thomas Hughes] “It loads to our Macs and plays fine. The only difference I can see is that our Macs are older. Also, our Macs have FC on them, his doesn’t. Does that make any difference?
    Sure, it makes huge difference. There are a number of codecs that only become available on systems when FCP is installed.
    You failed to mention which codec you edited and delivered to your client. That’s essential info for us.
    Was it HDV by any chance??? If so, that’s certainly one of the codecs those codecs that’s installed when FCP is installed.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • John Fishback
    October 11, 2011 at 8:25 pm
    Checkout this Adobe link re getting Pro Res codecs without a Pro App. Read down the entire page.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • David Roth weiss
    October 11, 2011 at 8:55 pm
    [John Fishback] “Checkout this Adobe link re getting Pro Res codecs without a Pro App. Read down the entire page.”
    Hey John!
    How do we know he’s using ProRes? Neil is the only one here who mentioned it. Thomas has not actually mentioned what codec he’s editing or delivering.
    David Roth Weiss
    Los Angeles
  • Steve Eisen
    October 11, 2011 at 9:13 pm
    The .mov mystery!
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • David Roth weiss
    October 11, 2011 at 9:21 pm
    [Steve Eisen] “The .mov mystery!
    Indeed!
    If I only had a nickel for all the times I’ve had to ask this most important question I’d be a rich man.
    And, if I had a dollar for every new poster who was afraid to admit they have no idea what a codec is I’d be a bit richer too.
    David Roth Weiss
    Los Angeles
  • Thomas Hughes
    October 11, 2011 at 9:50 pm
    Thank you very much everyone for responding to my question. We went ahead and redid the QT file using h264. I just gave it to my client on a USB flash drive. I expect when he tries it it will be fine. My editor was a little concerned saying that h264 may not look the best. Does that sound right? Is there another codec we could use that would look the best and definitely play on my client’s Macs? tx
    Thomas H
  • Steve Eisen
    October 11, 2011 at 10:14 pm
    So long as they transfer the file off the flash drive.
    Don’t want to hear: “when I play the file, it stutters.”
    Steve Eisen
    Vice President
  • John Fishback
    October 11, 2011 at 10:40 pm
    You’re right, David. I jumped before looking. Anyway, it’s an interesting link for those needing Pro Res without Pro Apps.
    John
  • Neil Patience
    October 12, 2011 at 12:54 pm
    Hi Thomas
    The problem with your question, as David points out, is that you have not told us the format of your pictures or what codec you have used or delivered in the first instance.
    Quicktime is in effect a container that can support many different file types and formats. So there are many variables.
    So its impossible to say what will be best as we dont know what you have in the first place.
    FCP offers additional encoding options over those supported by the standard Quicktime player. ProRes was the example that I gave as one that falls into this category.
    So it is possible for you to create a file that will not play on the standard player.
    H264 was the example I gave of something that will play on the standard player, your client should have no issue with that.
    However the quality of that file will depend on the parameters used to create it.
    So what seems a simple question is actually a little trickier to answer than it may first appear.
    Hope that makes sense
    best wishes
    Neil
