Activity Forums Apple Final Cut Pro Legacy Unable to perform edit to tape on Digibeta using SDI
  • Unable to perform edit to tape on Digibeta using SDI
    Posted by Jack Johnson on October 19, 2010 at 6:44 pm
    FCP 7
    AJA Kona LHe
    Digibeta DVW-A500
    SDI In and Out
    I have control of the deck and can log and capture fine. I need to black and code a tape and every time I press the button in the Edit to Tape window a get a dialogue box that says “Unable to perform Black and Code. The Tape appears to be write protected or the deck may be in Local mode.”
    Is there a setting I’m missing? Please help.
    Jack Johnson replied 15 years, 10 months ago 2 Members · 2 Replies
