Activity › Forums › Apple Final Cut Pro Legacy › unable to output image via firewire to camera
  • unable to output image via firewire to camera
    Posted by John Graves on December 3, 2005 at 4:13 pm
    Usually I use Igniter video card to go I/O. I don’t usually do firewire.
    I’ve been able to capture from firewire before, but now I’m trying to print to camera (in vtr mode) via firewire. I made sure that FCP’s external video is set to “Apple NTSC Firewire 720×480”, and the camera display says “DV in 16 bit”, however I was unable to get the camera (a sony DCR-PC100)to see an image. If the camera is not connected to DV, I get blue screen. If connected to my G4’s firewire, I get video black, but occasionally I got incoherent, blocky white-black pulses, but no image, as if the camera is trying to decode or make sense of the input. I have checked and rechecked every menu and control panel I can think of. Any Ideas?? I will be grateful if you can suggest a solution.
    regards
    -John
    Rob Forsythe replied 20 years, 10 months ago 2 Members · 2 Replies
  • John Graves
    December 3, 2005 at 4:14 pm
    PS: this is OS9.2.2, G4, FCP 3. Thanks
    -John
  • Rob Forsythe
    December 4, 2005 at 11:58 pm
    Is your TIMELINE preset to DV NTSC?
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    d. Being able to capture from a FW device.
    If working this list doesn’t cure the problem… you may have a serious PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Make sure you have chosen FW output for A/V:
    Final Cut Pro (menu) > Audio/Video Settings… >
    Video Playback: Apple FireWire NTSC (720 x480)
    Audio Playback: FireWire DV
    11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    15. Important: Quit FCP, then Restart FCP.
    16. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    >Then, start again at my “step 1” above.
