Activity Forums Apple Final Cut Pro Legacy Unable to output from FCP to Canon XL1.
  • Unable to output from FCP to Canon XL1.
    Posted by Phoenixandrew on September 27, 2005 at 9:54 pm
    I have an eMac with Final Cut Pro 4.5 HD. I also have a Canon XL1 3 CCD camcorder.
    I have no problem capturing footage from my camcorder to my eMac on FCP. I can also connect my Canon to my VCR and record off my camcorder to my TV, as well as play the tape on my camcorder to watch it on TV.
    However, I cannot output from FCP to my camcorder. The 4 to 6 FireWire is attached to both the camera and the eMac and I checked the Log and Capture feature and FCP does recognize a camera or deck is attached. I’ve been trying to output it using manual record in which I press record on my camcorder and play the playhead on FCP. As I record, there is no picture on my viewfinder, nor any audio being recorded and when I play it back, I just get this blank blue screen, but the timecode is recorded.
    Am I missing something here?
    Phoenixandrew replied 20 years, 11 months ago 2 Members · 2 Replies
  • Rob Forsythe
    September 27, 2005 at 10:07 pm
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    If working this list doesn’t cure the problem… you may have a PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    11. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    12. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    13. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    14. Important: Quit FCP, then Restart FCP.
    15. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    >Then, start again at my “step 1” above.
  • Phoenixandrew
    September 28, 2005 at 12:51 am
    Thanks Rob. I realized that all I needed to do was to go to View/External Video and I discoverd it was in the “Off” mode. I only needed to change it to “All Frames”. Thanks again.
