Activity Forums VEGAS Pro Unable to Import .MOV Files
  • Unable to Import .MOV Files
    Posted by Dankos on January 1, 2006 at 3:06 am
    Hi, I use Vegas Movie Studio 4 on a Win XP system. When I try to import a .MOV file created using a Nikon camera I get the error message
    “An error occured while opening one or more files.
    The file format plugin for the specified format was not properly initialized.”
    Is there any way to fix this? I tried a different editor and it had no problem.
    Ai Zongquan replied 16 years, 5 months ago 4 Members · 6 Replies
  • Edward Troxel
    January 1, 2006 at 12:45 pm
    Do you have quicktime installed? When you installed it, did you choose “custom” and install everything (especially the “Authoring” components?)
    Edward Troxel
    JETDV Scripts
  • Dankos
    January 1, 2006 at 6:03 pm
    After I posted my inquiry I downloaded the current version of Quicktime and installed it. That seems to have done the trick. Strangely, later when I tried to Vegas 4, the problem re-occurred. Now, this morning, it worked fine. I didn’t the notice the custom authoring option and I’ll look. BTW, why is that important?
  • Edward Troxel
    January 1, 2006 at 6:26 pm
    I think the “authoring” problem may have been eliminated in the most current version of Quicktime. I know it was a big problem with QT5. Just not sure about QT6 or QT7.
    Edward Troxel
    JETDV Scripts
  • Edward Troxel
    January 1, 2006 at 6:29 pm
    Edward Troxel
    JETDV Scripts
  • Skyhouse
    January 4, 2006 at 4:42 pm
    I HAVE HAD A SIMULAR ISSUE IN THE PAST, I JUST CHANGED THE EXT NAME
    ON THE FOLDER
    AS AN EX. INTRO.VOB I WOULD CHANGE TO INTRO.AVI OR INRO.MPEG TILL
    IT WORKS
  • Ai Zongquan
    March 20, 2010 at 11:01 am
    you can try a kodak video converter,it help me a lot
