Activity Forums Adobe Premiere Pro Unable to import HDV into CS6 – “codec missing or unavailable”
  • Unable to import HDV into CS6 – “codec missing or unavailable”
    Posted by Al Jensen on April 25, 2014 at 6:20 pm
    I’m trying to import some HDV footage into Premiere CS6 on Windows 7 64-bit, but it says “codec missing or unavailable”. I’m fairly familiar with these issues, and can usually solve them without too much of a hassle, but this one has me puzzled.
    Media Info says:
    Format : MPEG-4
    Commercial name : HDV 1080p
    Format profile : QuickTime
    Codec ID : qt
    Writing library : Apple QuickTime
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High 1440
    Codec ID : hdv6
    I originally tried to import it into an existing timeline, but it failed. So I created a new project and specifically chose the HDV 1080 24p preset, and I was still unable to import it due to missing codec.
    I then installed the latest version of Quicktime, but that didn’t work… and in fact, they don’t even open in Quicktime, it says “additional components are required to play this video” but doesn’t say what they are.
    I can play them fine in Media Player Classic decoding them with FFDShow, but I can’t get them to open in Virtualdub so I can convert them into AVIs.
    Any help would be appreciated. Thanks!
    Zeb Hansell replied 11 years, 11 months ago 6 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    April 25, 2014 at 6:27 pm
    Where did this HDV footage come from? If this was captured in FCP, then the HDV codec is proprietary to FCP…you need FCP installed in order to see it. Apple did that with DVCPRO HD too. They are native, no loss….but the codec is tied to the pro app.
    Shane
    Little Frog Post
  • Al Jensen
    April 25, 2014 at 6:35 pm
    I got it from another guy who was filming, and he does indeed use FCP. Googling around it looks like if you’re on a Mac and you don’t have FCP you can install “ProApps Quicktime Codecs”, but that doesn’t work for Windows. It sounds like you’re right.
  • Tim Kolb
    April 25, 2014 at 6:43 pm
    If it was an FCP Log and Capture re-wrap, it would be a .mov.
    If it’s an MP4 file and still shows “HDV” it’s probably a 25 Mbit/s MPEG2 file from an XDcamHDEX camera, which wrapped its MPEG2 files as MP4s (yes, I know other XDcamHD is wrapped as MXF…no, I have no idea why they did it that way.)
    Is this a Premiere Pro installation you’ve been using for some time, or a new installation?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Chris Borjis
    April 25, 2014 at 8:48 pm
    Al, are these .mov files?
    If so you will need to have someone transcode them to another pc friendly format.
    I had to convert a few hundred HDV .mov clips for a client a month ago.
    They had me transcode them to pro res.
  • Al Jensen
    April 25, 2014 at 9:03 pm
    It’s a .MOV file. I’ve been using this install of CS6 for a little over a year, but this is the first time I’ve tried to use his footage since he switched cameras. It never occurred to me it would be an issue 🙂
  • Kevin Monahan
    April 25, 2014 at 9:05 pm
    Hi Al,
    You can try the Calibrated{Q} XD Decode plug-in and work with those files on a PC: https://www.calibratedsoftware.com/products.asp
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Tim Kolb
    April 25, 2014 at 9:15 pm
    [Al Jensen] “It’s a .MOV file. I’ve been using this install of CS6 for a little over a year, but this is the first time I’ve tried to use his footage since he switched cameras.”
    It’s not his camera…it’s that he let FCP get a hold of the footage first and it re-wrapped it into one of Apple’s proprietary codecs.
    If he had the original footage, you could handle that without a problem.
    The Calibrated plugin that Kevin mentions is a pretty solid approach.
    TimK,
    Kolb Productions,
  • Al Jensen
    April 25, 2014 at 9:22 pm
    [Chris Borjis] “Al, are these .mov files?
    They had me transcode them to pro res.”
    Yeah, they are. Okay, that pretty much makes it official then. I’ll contact him and see if he can send me them in a different format since I was unable to convert them using Virtualdub, even with AVISynth.
  • Al Jensen
    April 25, 2014 at 9:24 pm
    Very interesting, thanks for the link.
  • Zeb Hansell
    September 24, 2014 at 7:42 pm
    The TRICK THAT WORKED for me, on Mavericks 10.9.5 was to (force) instal the Mac ProAppsCodecs
    REF 1: https://forums.adobe.com/message/4795554
    REF 2: https://www.youtube.com/watch?v=fSFIQSXJ4RE
    REF 3: https://www.martin-thoburn.com/vj/install-apple-prores-codec-without-final-cut/
    Rebooted Adobe Premiere (CS6) and viola, importing and working with all my .mov files again 😉
