Activity Forums AJA Video Systems Unable to get composite signal to FCP
  • Unable to get composite signal to FCP
    Posted by Greg Ammen on April 15, 2009 at 6:07 pm
    Hello,
    I am having trouble getting a composite signal to FCP.
    I can see the video on my monitor from the composite OUT on the IO LA however when I use the Composite Easy Setup on FCP I don’t see video on Log and Capture only the Preview Disabled message.
    When I shutdown FCP and open up the ProIO Control Panel it tells me No video on the Analog IN.
    The Analog input Video Format is set to: Composite
    Am I missing a step?
    My system:
    Mac G5 OSX version 10.5.6
    Final Cut Pro 6.0.5
    ProIO Control Panel 1.2
    AJA IoLA
    I appreciate the help
    Greg
    Greg Ammen replied 17 years ago 4 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    April 16, 2009 at 4:42 pm
    What’s your composite source?
  • Greg Ammen
    April 16, 2009 at 5:12 pm
    The composite source is a VCR. I have also tried it with a DVD player and our Sony DSR-11 DVCAM Deck. Thanks for your help.
    -Greg
  • Jeremy Garchow
    April 16, 2009 at 5:24 pm
    Whhen you are in FCP and choose the proper easy setup, does the analog composite light come on?
  • Greg Ammen
    April 16, 2009 at 5:35 pm
    Yeah the light comes on when a composite Easy Setup is chosen. It also comes on when I shutdown FCP and open the ProIO Control Panel and select “Composite.”
    However, even though I am seeing signal on the monitor from the Composite Out on the AJA, the Control Panel is indicating no video on the Analog In.
    -Greg
  • Jeremy Garchow
    April 16, 2009 at 5:51 pm
    I can’t remember. Does the ioLA control panel have an input passthrough mode?
    If so, can you set the input to composite and see an image on a monitor hooked up to the LAs output?
    Jeremy
  • Greg Ammen
    April 16, 2009 at 6:33 pm
    Jeremy thanks for your help.
    There is no way to select a passthrough mode but it appears that may be a default since I am seeing video on the monitor.
    I have the Monitor hooked up to the ioLA composite output. Sorry if I wasn’t clear, that is what I was indicating by this:
    “However, even though I am seeing signal on the monitor from the Composite Out on the AJA, the Control Panel is indicating no video on the Analog In.”
    Again, thanks for your time.
    -Greg
  • Gary Adcock
    April 16, 2009 at 9:33 pm
    [Greg Ammen] “There is no way to select a passthrough mode but it appears that may be a default since I am seeing video on the monitor. “
    correct all outputs are active all the time.
    the only time I see this as an issue is when there is more than 1 FW device on the chain.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Greg Ammen
    April 16, 2009 at 9:55 pm
    Hmm…
    I definitely only have one FW device plugged in (the AJA ioLA.)
    Also just to verify that something hadn’t hung up I checked System Profiler and the AJA is the only thing showing up on the FireWire Device Tree.
    One other thing to note, which I neglected to mention and I know may be asked later, I have restarted the machine and reinstalled and updated the ProIO Control Panel.
    Thanks.
    -Greg
  • Simon Weaver
    April 16, 2009 at 10:03 pm
    Have you ever had a composite signal, or has it just gone down? I only ask because my first AJA box never did – and was eventually returned for a replacement unit.
  • Simon Weaver
    April 16, 2009 at 10:16 pm
    I would – they swapped mine straight away – great service.
    Always Learning!
