Activity Forums Apple Final Cut Pro Legacy UNABLE TO EXPORT TO MiniDV CAMCORDER
  • UNABLE TO EXPORT TO MiniDV CAMCORDER
    Posted by Dunwoody Lampton on March 5, 2006 at 5:47 am
    F.C.P. HD, POWERMAC G5, LACIE EXTERNAL FIREWIRE, PANASONIC AG-DVC60
    tried to export, make movie, print to video – all methods outputting
    nothing to camcorder through FireWire i/o connector. no audio.
    no bars. no tone. no video. no timeline sequence.
    timeline has been rendered.
    first attempt to input DV signal into camcorder. analog has been
    successfully input before. no other DV device around to test.
    Dunwoody Lampton replied 20 years, 6 months ago 2 Members · 2 Replies
  • Shane Ross
    March 6, 2006 at 10:27 am
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Dunwoody Lampton
    March 8, 2006 at 12:02 am
    thanks so much for your quick response, shane!
    no, i did NOT have an external monitor hooked up,
    because i’ve been able to see and hear previous
    analog inputs in the flip-out LCD panel on my camera.
    however, i also did NOT utilize any of the other six
    steps you mentioned, either, so i believe therein
    lies the problem.
    will test tomorrow.
    thanks again.
