Activity › Forums › Adobe Premiere Pro › Unable to edit sequence settings in CS6
Posted by Graham Hutchins on May 29, 2012 at 5:26 pmHello all,
I would like to be able to change the sequence settings for a given sequence, but all of the useful parameters are either greyed out or otherwise un-editable.
Here’s a screen shot of what I’m referring to:
I am currently on a trial version of CS6, if that makes a difference, although I imagine it shouldn’t.
Thank you for your time.
-Graham
OSX 10.7.4, Windows 7
Adobe CS6
FC Studio 3
Octo 2.26GB MacPro, 32 GB RAMKekura Reddy replied 10 years, 8 months ago 14 Members · 21 Replies -
Chris Borjis
May 29, 2012 at 5:28 pmunfortunately they can’t be altered.
you have to create a new sequence with settings you want
then copy the contents of the other sequence and paste
them into the new one. -
Kevin Monahan
May 29, 2012 at 5:30 pmThere is no way to change certain settings for certain sequence presets.
Solution: Make a new sequence in the same project with the correct settings and copy all the contents from the original sequence and paste into the correct one.
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Graham Hutchins
May 29, 2012 at 5:31 pmHi Chris,
Thanks for the response.
Wow, well that’s pretty lame. What you suggested is what I’ve been doing, I just thought there was something awry.
Off to the Adobe feature request website! (again)
Thanks again!
-Graham
Adobe CS6
FC Studio 3
Octo 2.26GB MacPro, 32 GB RAM -
Graham Hutchins
May 29, 2012 at 5:46 pmHi Kevin,
I’ll be visiting the Adobe feature request website to log this. Seems like kind of a weird thing to leave out. Every single timeline based app I’ve ever used, FCP, AVID After Effects, has the ability to do this.
Re: your solution, yeah, that’s what I’ve been doing. Even custom sequence setups are uneditable once the sequence is made, though.
Would you mind expanding on why this is the way it is? Is it simply a functionality that wasn’t addressed and could be easily added, or is there a more “if we don’t do this this way, it will break something” reason for doing things this way, something at a deeper, media player/code level. I’d like to have as much control as possible with apps I use and I hope that Adobe isn’t trying to protect users from themselves with this implementation. As it stands now, what should be a one step process currently takes 7 steps. This is bad UI design.
Any thoughts?
-Graham
Adobe CS6
FC Studio 3
Nevin Styre
May 29, 2012 at 6:27 pmEven in FCP7 you can’t change the sequence framerate or field dominance after you start editing, though frame size/pixel aspect ratio & codec can still be changed, these options at least would be nice to make there way to PP as editable after editing though.
Graham Hutchins
May 29, 2012 at 6:36 pmHi Nevin,
You can change the frame rate and field dominance, you just have to select everything in the timeline, cut, make changes to sequence settings, and then paste everything back. Not as elegant as it could be, but it works.
-Graham
Adobe CS6
FC Studio 3
Kris Merkel
May 29, 2012 at 7:51 pmSorry, I have to ask? Why would you want to change your sequence setting mid edit? Might be able to help with an alternate workflow solution if we knew why this was a necessity.
“Think of everything in terms of building capacity.”
Kris Merkel
twitter: @kris_merkel
Product Specialist, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com2.2Ghz MBP core i7
16Gb RAM
CS 5.5
FCP7 and Studio
Blackmagic Design UltraStudio 3D
AJA IO XT
FSI LM-2340W -
Kevin Monahan
May 29, 2012 at 8:54 pmGraham,
I’m not an engineer, so I really can’t answer why a certain feature is not implemented the way you expect it to work. All I can suggest is to make a feature request. We actually read them and implement ones that matter most to our users.Sorry I can’t give you a clearer rundown.
Kevin Monahan
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Graham Hutchins
May 29, 2012 at 9:15 pmYeah, except that you have to cut the media from the timeline, create a new sequence, either use a preset or define the sequence parameters, rename the sequence, open the sequence, and then finally paste in the timeline.
Cut, command+0, edit parameters, return, paste. Fewer steps, but still pretty lame that have to do it in the first place.
-Graham
Adobe CS6
FC Studio 3
