Activity Forums Apple Final Cut Pro Legacy Unable to copy and paste audio Transitions in FCP7
  • Unable to copy and paste audio Transitions in FCP7
    Posted by Andy Harrison on March 11, 2010 at 11:45 am
    Hi Cows,
    I have upgraded to FCP 7 but I am currently unable to enjoy the ‘copy audio transitions’ feature on my system. I have used other systems and alt dragging an audio transition to another single transition or a host of selected audio clips works great. However whenever I try on my Mac I am met with the following error message:
    ‘There was insufficient media for the requested transition at one or more edit points. Would you like to accept others?’
    If I click yes I am left with a shorter transition and it is not aligned correctly. I can manually create the transition I want proving there is sufficient media, I am just unable to copy the transition from one clip to another. This has become really frustrating!!!
    Does anyone know what I need to change within my FCP settings to make this feature work?
    Any advice would be much appreciated.
    Many Thanks
    Andy
    Andy Harrison replied 16 years, 3 months ago 3 Members · 4 Replies
  • Victor Perez
    March 11, 2010 at 3:45 pm
    Sounds like one/both of the clips/audio tracks do not have handles to allow for the transition you desire.
    For a better explanation search Handles in the FCP User Manual under the help menu.
    You can also check for handles by pressing the S key and then clicking on the clip/audio you want to add the transition to. A grey highlight will show you how much extra media you have available to add the transition.
    good luck,
    Victor
    Victor
    http://www.editvictor.com
  • Andy Harrison
    March 11, 2010 at 3:53 pm
    Thanks Victor,
    But as I said in my original post – I am able to create the transition manually as there is enough media for handles. What I’m not able to do is alt+drag the same audio transition from one clip to another. There is definitely enough media which is why I am finding this so frustrating. Is there a setting anywhere in the preferences that would affect this?
    Best
    Andy
  • Calixte Govaarts
    June 2, 2010 at 12:36 pm
    I have the same problem. Do you already know how to solve this problem?
    kind regards
    Calixte
  • Andy Harrison
    June 2, 2010 at 1:57 pm
    Hi Calixte,
    I haven’t fully resolved the issue as yet but I have discovered why I was getting the error message. When I create my inital audio transition using the short cut for my favourite audi transition (alt+cmd+t), I am not able to copy the effect by alt dragging it to other clips – as per my original post.
    However if I add the initial transition by going straight to the effects tab, rather than using the shortcut, I can manipulate the transition and copy it to other clips withoput any problems.
    I hope this helps.
    Cheers
    Andy
