Activity › Forums › Blackmagic Design › Ultrascope and render farm
  • Ultrascope and render farm
    Posted by Stuart Smith on January 25, 2010 at 5:59 pm
    Hey,
    We’re looking at getting 6 Ultrascopes and running them on the HP XW4600. Does anyone know if we’d also be to use those systems in a render farm for Maya, Cinema 4D etc, while running the Ultrascope app?
    Joshua Helling replied 16 years, 8 months ago 3 Members · 3 Replies
  • Bob Zelin
    January 26, 2010 at 3:25 am
    the Ultrascope won’t mind, but I bet the render farm software will (not like having another application running – even a low overhead one).
    Bob Zelin
  • Stuart Smith
    January 26, 2010 at 4:20 am
    I guess a better question would be if Ultrascope is strictly GPU intensive? Then there would be no problem.
  • Joshua Helling
    February 2, 2010 at 10:41 pm
    Hrm…untested obviously. However yes…it is more GPU intensive. It doesn’t like to be defocused so if the render node is happy to run in the background it might work.
    Obviously, if there is an issue and you call us we will have to ask you to check your results against the system without the render node turned on…but, yeah…you know.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
