Activity Forums Lighting Design UK equivalent of Can Light? (Would a work light work?)/ Dedolight Alternative
  • UK equivalent of Can Light? (Would a work light work?)/ Dedolight Alternative
    Posted by Jamie Macleod on September 17, 2014 at 1:56 pm
    So in the UK ‘Can (or Clamp) Lights’ aren’t anywhere near as easy to get a hold of as in the USA. However work lights are. So could I go ahead and get a 150w clamp on work light and get a similar effect (e.g. https://www.silverlinetools.com/cs-CZ/Products/Torches%20and%20Lamps/Work%20Lights/459873)?
    To give you some context. I am trying to get something that is a more DIY alternative to a set of 150W DedoLights. Ideally I wan’t something that is a bit more of a focused light than just a full wash, which is why I originally gravitated towards trying to find clamp lights instead of using work lights.
    If anyone has any other suggestions they would be greatly appreciated!
    Jamie Macleod replied 11 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
