Typography Audio Trouble
Greetings,
This is my first post to the forum, but I have visited many times for tips. I run into this problem from time to time, and I’m just curious to know if anyone else has this issue.
When creating typography I notice the audio skips and does not play in sync with waveform. The audio waveforms are at times not even present. Then there are times when the audio will play and skip to a totally different place within the audio track. I closed out of the waveform view,opened in the viewer, and the audio continues to skip around. I don’t have any other programs open that would use ram. Not really sure about this one. Any advice would be appreciated.
System:
Imac
20″
2.16 GHz Intel Core 2 Duo
3 GB 667
Version 10.6.4
AE CS5Walter Marshall
Twitter.com/WalterVMarshall
