Activity Forums Apple Final Cut Pro Legacy Typewriter text generator problem
  • Typewriter text generator problem
    Posted by Ste Kerouac on July 1, 2006 at 2:14 pm
    I’m using the typewriter text generator. I want it to type a piece of text on and then stop and hold the full text for a while. I’ve tried keyframing the ‘pause’ property but that seems to be a little unpredictable. Then I tried taking the last frame with all the text on and did shift-N to make a freeze frame. But the freeze frame it generates is from a previous point when the text was not all on screen yet…. Any ideas? Must be quite a common problem.
    Kevin Monahan replied 20 years, 2 months ago 2 Members · 1 Reply
