Activity › Forums › Adobe After Effects › type glow query
type glow query
Posted by Chris Brett on March 27, 2014 at 3:34 pmHi — trying to get a white glow behind some black type ie black tyoe is unaffected by white glow behind ( as found in PS ) ……
…… think I’m making hard work of this – currently using multiple white drop shadows with no distance and lots of blurring ….
———– anyone know the easy way please ?
————————chris —
Chris Brett replied 12 years, 6 months ago 3 Members · 6 Replies -
Chris Brett
March 27, 2014 at 4:27 pmHi Dave
— thanks for speedy reply —- much appreciated
————- problem with the drop shadow method is client wants MASSIVE white ‘ glow’ and it requires many multiple copies all maxed out which is clunky as have quite a bit of type do with this ..
— will try other method and see if its more manageable —
————– all the best —
———————————chris
Shay Carriere
March 27, 2014 at 8:30 pmAnother option if your background is dark is to duplicate the text, make it white, add a fast blur and set the blending mode to add. Drop it underneath the original. With the fast blur you can get a pretty good spread and it renders pretty quick.
Chris Brett
March 27, 2014 at 8:37 pm— Hi Dave —
— used the glow method and it worked just fine – will remember follow-up comments and check it out next time…
I guess as much as anything I was wondering if there is a text setting — such as ” outline / ouline width / soften / etc ” …..
—– once again, many thanks ——–chris —
Chris Brett
March 27, 2014 at 8:40 pmHi Shay
— thanks for this,sounds like a good one ..
– its easy to overlook the blending options…..
———————– — cheers —-chris
Kevin Camp
March 28, 2014 at 9:34 pmi would think layer styles>outer glow would do well, it has settings fo both size (feather) and spread, which can really heavy it up.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW -
Chris Brett
March 28, 2014 at 10:48 pmThanks Kevin –
– did not know about this — will check it out tomorrow .
All the best
——————- Chris —
