Activity Forums Adobe After Effects Tyler Pauls Toonificator V3.2 – Many Improvements
  • Tyler Pauls Toonificator V3.2 – Many Improvements
    Posted by Tyler Paul on December 17, 2006 at 5:47 pm
    Example Clip
    7.0 Project File
    Replace the missing jpeg file with your video.
    Adjust the Footage comp, Combine comp and Post comp to the length of your clip. Nothing over 15 minutes. A 15 minute clip will take more than 10 hours to render.
    In the Footage comp make any needed color adjustments to your footage.
    If you can’t get the desired result by adjusting your footage there is an Adjustment comp with a levels effect in it. You can adjust the black and white inputs for more control over the tooning process.
    There are three items in the render queue. The first two are prerenders and the third is your final clip. Make any needed adjustments there.
    So that’s it for awhile. I’m happy with the results considering I was attempting the impossible.
    “Life Should Come With Backround Music”
    -Brown Sugar Studios-
    Tyler Paul’s Toonificator V3.0Example Clip
    Tobias Pfeiffer replied 19 years, 8 months ago 2 Members · 1 Reply
  • Tobias Pfeiffer
    January 6, 2007 at 4:45 pm
    hi,
    your toonificator 2.0 comes with lots of presets and a manual.
    does these presets (and the manual) work with version 3.X too?
    thanks,
    payton
