Activity Forums Adobe After Effects Tyler Paul’s Toonificator V3.0 The Update To End All Major Updates!
  • Tyler Paul’s Toonificator V3.0 The Update To End All Major Updates!
    Posted by Tyler Paul on November 16, 2006 at 9:02 pm
    This project is a success.
    Clip 1
    and superman returns should have been a cartoon.
    Clip 2
    The video was very compressed and it still came out pretty great.
    Download the project file here. All you have to do is open the project file and replace the missing video clip with one of your own. And then, unfortunatly, you must go through everyone of the some 13 comps and change the size, length, frame rate etc to match your footage. At some point I think I might make a script so that you’ll just have to make one comp with your footage and the rest will be done by itself… but not for awhile. The second major hit is the render time. A minute of footage tends to take a little over an hour. ouch. On the Post comp there is an adjustment layer with an alpha levels effect on it. Adjust the Input Black and the Input White for some control but it generally isn’t necessary. Finally just go to the render que. Two comps are already there. The first is a precomp the other is the final movie. Make any adjustments and render.
    Tyler Paul replied 19 years, 9 months ago 4 Members · 5 Replies
  • Mike Clasby
    November 16, 2006 at 10:03 pm
    Argh! You are worse than Lex Luther, you’ll make me upgrade to AE7 yet.
    Nice.
  • Tyler Paul
    November 16, 2006 at 10:36 pm
    Well, I’m pretty sure the most current effect that is used is CC vector blur which became available in 6.5. What other ways are there to transfer this template? Like I said, I may make the script but it would be very tedious and I don’t have the time. I imagine you can use animation presets within the script. That would make it a hellovah lot easier. But are there any other possibilities that I’m missing?
  • Steve
    November 17, 2006 at 2:27 pm
    That looks very good, everytime you submit a clip I feel like watching the whole movie lol, the whole bicycle cop thing was pretty funny. Keep up the good work.
  • Andrew Kramer
    November 17, 2006 at 9:07 pm
    Very Cool! This one is Top Notch.
    Thanks for sharing.
    Andrew Kramer
  • Tyler Paul
    November 18, 2006 at 12:46 am
    Andrew Kramer, you just made my day.
    “Life Should Come With Backround Music”
    -Brown Sugar Studios-
    Tyler Paul’s Toonificator V3.0Example Clip
