Activity Forums Adobe Premiere Pro Two versions of Premiere Pro on same computer?
  • Two versions of Premiere Pro on same computer?
    Posted by David Dicanio on December 27, 2007 at 3:43 pm
    I know this has been asked before but I cannot find a thread in the search. I have a computer running PP1.0 XP service pack 1 with a matrox RT.x2 card. I recently got a HDV camera and CS3. I’m still finishing up an old project on the pp1.0 version and don’t want to remove it just yet. But I have to import some HDV footage and down convert it letter boxed on the import. I need to use the newer cs3 version to do that. Can I install cs3 along with 1.0 without any conflicts? I do not plan on opening the 1.0 projects in the CS3. I only plan on importing HDV footage and down converting it on import. Thanks very much for any help.
    Ben Nardone replied 18 years, 8 months ago 6 Members · 6 Replies
  • Vince Becquiot
    December 27, 2007 at 3:46 pm
    I’d say the rule is NEVER upgrade or update while working on a project.
    Vince
  • Lloyd Coleman
    December 27, 2007 at 4:30 pm
    I ran two versions on two different machines and did not have any problems.
  • Mike Velte
    December 27, 2007 at 8:27 pm
    I dont think you will have any issues…but have plan B just in case; Lloyd, why not give David your cell phone number so he can call you for help if needed!
  • George Socka
    December 28, 2007 at 3:56 am
    I have 6.5, 1.0 and CS3 all running on the same XP computer right now. Even accidently started 2 versions at the same time with no ill effects. You need to manage your third party plugins so they show up in both places properly. And once you install CS3, if you just click on a project file, CS3 will try to open it. Just don’t let it save if you need to go back.
    Nothing Matrox anywhere near this computer since 6.5 was 6.1 though.
    George Socka
    BeachDigital
    http://www.beachdigital.com
  • David Dicanio
    December 28, 2007 at 8:30 am
    Thanks for all the help. I’ll give it a try.
  • Ben Nardone
    January 3, 2008 at 8:15 pm
    I run 2 & 3 and haven’t run into conflicts yet, though I don’t do a ton of video work with them. I have edited a couple old projects with 2, and some new ones with 3. 3 can’t play the source files that worked fine in 2 for some reason, so I still wind up using 2 half the time.
    :)Ben
    http://www.pathfind.org
