Activity › Forums › Creative Community Conversations › Two Sound Questions
  • Two Sound Questions
    Posted by Sascha Engel on July 24, 2013 at 11:24 pm
    Hallo Everybody,
    I am about to start my first short film in FCPX, since I cannot L&T anymore in FCP 7 in 10.8.
    Now, two things that still worry me:
    1. When I did some test import, it brings in the C300 Canon Footage with linked Stereo Files, but I need them separate, since I need to control them individually (one is Boom, one neck mic). How can I delink them, like in FCP with option + L?
    2. In the end I have to deliver a full OMF file to the Sound Studio, how can I do this FCPX?
    Thanx a lot.
    Greetings,
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
    Michael Gissing replied 13 years, 2 months ago 4 Members · 19 Replies
  • 19 Replies
  • Andy Neil
    July 25, 2013 at 12:06 am
    You should be able to just check the box on import that says, “Separate Mono and Group Stereo audio”. Otherwise, you could select all your clips once you’ve imported and in the inspector change the audio configuration to dual mono instead of stereo.
    Andy
    https://www.timesavertutorials.com
  • Charlie Austin
    July 25, 2013 at 12:18 am
    [Andy Neil] “You should be able to just check the box on import that says, “Separate Mono and Group Stereo audio”. Otherwise, you could select all your clips once you’ve imported and in the inspector change the audio configuration to dual mono instead of stereo.”
    Correct, it’s a button click away. FWIW, any common attributes of multiple selected files, audio or otherwise, can be manipulated in the inspector.
    As to OMF, get X2Pro (LE or Professional) and send ’em an AAF. It works great and will import to most common DAW’s (Logic, ProTools, Nuendo etc) If they insist on an OMF, use Xto7 to bring it into FCP 7, do whatever cleanup needs doing, and export OMF from there. I would add that it is very important to assign the correct Roles to your Audio before you start cutting. You can do it anytime, but trust me, you want to do it in the Event. Do that, and everything is super easy. 🙂
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Sascha Engel
    July 25, 2013 at 12:30 am
    Thanx a lot. Yes, i managed to split the Audio like this. Unfortunately when bringing it into FCPX, even with the Mono box checked it would not do it. So, no way around the pricey third party software? Could you elaborate on the roles, since that is a part of FCPX I am not so familiar with yet.
    Greetings,
    Sascha Engel
  • Andy Neil
    July 25, 2013 at 12:37 am
    [Sascha Engel] “Could you elaborate on the roles, since that is a part of FCPX I am not so familiar with yet.”
    Here’s a primer tutorial I did on the Roles feature.
    FCPX INs and OUTs – Roles
    Hope this helps.
    Andy
  • Charlie Austin
    July 25, 2013 at 12:44 am
    [Sascha Engel] “So, no way around the pricey third party software?”
    Well, you can just bring it into FCP 7. You will need Xto7, but it really is worth it. Also, the LE version of X2Pro is fairly reasonable, though it doesn’t give you as much control as the pricey version. And do check out Andy’s tutorial, as well as the thread comment’s below it. 🙂
  • Sascha Engel
    July 25, 2013 at 12:50 am
    Thanx a lot!
    Sascha Engel
  • Sascha Engel
    July 25, 2013 at 4:26 am
    Great Tutorial. Thanx a lot!
    Way more clear now. Roles is a strong tool, even though it doesn’t help me to get around this non OMF issue.
    Seems like the only way is to get X2Pro.
    While I still wonder, what the difference is between the Pro and LE version..
    Greetings,
    Sascha Engel
  • Charlie Austin
    July 25, 2013 at 4:31 am
    [Sascha Engel] “While I still wonder, what the difference is between the Pro and LE version..”
    https://x2pro.net/feature-list.html
    The biggest difference is that the “pro” version can trim your media. Without that, the files are absolutely gigantic as it copies the entire source file, even if you only used 10 frames from it. Almost unusable if you have to send them out.
  • Sascha Engel
    July 25, 2013 at 4:39 am
    Thanx for all the information. So with Xto7 I can get the project fully onto 7 and then do OMF from there?
    Sascha Engel
  • Sascha Engel
    July 25, 2013 at 4:43 am
    Could I not just export an XML from X and then import that XML to 7 and from there export an OMF, without any additional software?
    Sascha Engel
