Activity Forums VEGAS Pro Two rendering problems
  • Two rendering problems
    Posted by Joao Souza on December 16, 2011 at 4:43 am
    Hi guys.
    1- If I join different clips with different resolutions, I set them to match my preview screen but they render in their original sizes and I can see in my preview screen they’re rendering in their original sizes.How can I make them render in the size I set or at least in the same size as my project?
    2- Let’s assume I have a background picture with an opened window.If I put a clip in that window hole, after rendered it’s in a wrong place and while rendering I can see it’s in a wrong place.How can I make things render in the same places I put them?
    Thanks guys 😉
    John Rofrano replied 14 years, 8 months ago 2 Members · 3 Replies
  • John Rofrano
    December 16, 2011 at 1:35 pm
    [Joao Souza] “1- If I join different clips with different resolutions, I set them to match my preview screen but they render in their original sizes and I can see in my preview screen they’re rendering in their original sizes.How can I make them render in the size I set or at least in the same size as my project?”
    Project size and render size have nothing to do with each other. Clips will always render in the size of the render template you use regardless of the project size.
    [Joao Souza] “2- Let’s assume I have a background picture with an opened window.If I put a clip in that window hole, after rendered it’s in a wrong place and while rendering I can see it’s in a wrong place.How can I make things render in the same places I put them?”
    You need to make sure that your project size and render size match. If they don’t, things will get misaligned as you have seen.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Joao Souza
    December 16, 2011 at 5:16 pm
    Both have the same values 😉
  • John Rofrano
    December 17, 2011 at 6:29 pm
    Could you post a screen shot of your project properties window and your render settings window. I’d like to see if there is anything about them that I could spot that might be causing this.
    ~jr
