Activity Forums Apple Final Cut Pro Legacy Two questions about HDV in FCP5
  • Two questions about HDV in FCP5
    Posted by Robin on June 1, 2005 at 11:23 pm
    Hello!
    Does anyone know if it’s possible to shoot or edit 4:3 aspect using a Z1E and FCP?
    Also I don’t have an HDV monitor at the moment, can I still get synch sound by changing the audio/video settings to the computer? or do I use an analogue out from the camera to a regular monitor?
    Basically what’s the best way of getting synch when cutting HDV without an HD monitor, or should I use a regular CRT broadcast monitor just for synch?
    I’m confused!!!
    John Treffer replied 21 years, 3 months ago 4 Members · 6 Replies
  • Graeme Nattress
    June 1, 2005 at 11:26 pm
    HDV is always 16:9
    You cannot view HDV back through the camera like you do DV. You need to use a HD card like the decklink and appropriate SD or HD monitor to see it externally.
    Graeme
    http://www.nattress.com – Film Effects for FCP
  • T. J. shank
    June 1, 2005 at 11:39 pm
    I have had a different experience from Graeme with monitoring. I use an old Sony firewire to composite adapter (a DMC-DA1 or something like that – it’s not in front of me right now).
    I have been able to monitor on a standard NTSC monitor (the image comes in letterboxed) right from FCP. I haven’t tried using the camera as an adapter, but it seems reasonable that if the DA1 works, a camera should.
    tjs
  • Graeme Nattress
    June 2, 2005 at 1:04 am
    You’re monitoring HDV in HDV MPEG2 format straight out of FCP while editing???
    Graeme
  • Robin
    June 2, 2005 at 11:28 pm
    Interesting conflict of opinions.I’ll have to test.
    Haven’t answered my question about synch though. If I don’t use a ‘broadcast’ external monitor, will I have synching issues?
  • Robin
    June 2, 2005 at 11:29 pm
    Just trying to think of a work flow for my project
  • John Treffer
    June 3, 2005 at 12:15 am
    apple advocates the use of apple cinema desktop, any monitor connected to an AGP-graphics card as reference monitor. They don’t recommend it for interlaced video though.
    Still I expect it to generate pretty good quality on the 1080i signal of the Z1, I have not seen it yet though.
