Activity › Forums › Apple Motion › two questions
two questions
Posted by Matt on July 11, 2005 at 1:31 amI have a logo I imported into motion, in photoshop it has a transparent background but when I bring it into motion the background is white, how can I keep the transparency?
Also I want to make the logo shake, like an earthquake, is there an easy way to do this in motion?
I’m using version 1
ThanksScot Walker replied 21 years, 2 months ago 5 Members · 6 Replies -
Richard Harrington
July 11, 2005 at 1:34 amGo to the Photoshop forum and look up Alpha Channel
As far as shaking… look for Wiggle… not in front of Motion. but there is a logically named behavior that does this
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.comedit – produce – direct –
Matt
July 11, 2005 at 2:01 amFirst question solved, the images where cmyk, switched to RGB and everything is cool, Still trying to figure out the earthquake shake thing though
Matt
July 11, 2005 at 2:16 amI searched wiggle and nothing comes up. I know there is an earthquake behavior but that is a text behavior, it works great with text, but this is a logo, I cant get it to work with the logo.
Jayson Steckler
July 11, 2005 at 7:19 amright click on the logo’s position parameter.
select wiggle
adjust to your liking.
or…
throw an earthquake filter on the log (if you’re running M2)
Mathieu
July 12, 2005 at 2:46 pmJust add a RANDOM behavior to X and Y position of the object (or layer for simultanious effect on many objects) for the earthquake.
Scot Walker
July 12, 2005 at 3:53 pmLook at the parameter behaviors and apply them to the X and/or Y position of your object.
