Activity Forums Adobe Premiere Pro two odd behaviours – anyone seen these?
  • two odd behaviours – anyone seen these?
    Posted by Baba Goof on August 20, 2006 at 6:07 pm
    i’ve seen this first one on v1.5 as well as 2, on 24p dv as well
    as hdv in various forms, and on different systems. sometimes my
    timeline clips don’t meet up on the timeline when i try to place
    them adjacent to each other (a cut from one to another). i get a
    small empty space of less than a full frame. one clip ends between
    frames. often this clip doesn’t want to be extended to the even
    frame. a ripple delete doesn’t work to get rid of the space. often
    the adjacent clip can be used to extend and fill the space. what’s
    this all about and how do i avoid it?
    the second is that frequently if i’m near the end of a sequence
    and try to play, i cannot. the play cursor jumps to the end of the
    last clip. usually occurs when within a few seconds of the end.
    happens with both the space bar and the l key.
    anyone know how to avoid this one? or undo it?
    Toni White replied 19 years, 10 months ago 2 Members · 2 Replies
  • Toni White
    November 14, 2006 at 8:18 am
    Did nobody answer on this question? Because I have the same.
    I recorded in 24p AGDVX100 and am editing in a standard premiere project (upper field) I thought this would be the problem… So how did you record it, or did you allready found the answer ? (I have to finish a film in two days… so I woul really like to know as well…)
    Grt ton
  • Toni White
    Grt ton
