Activity Forums Apple Motion Two Motion Blur Image Units on Same Layer – PROBLEM
  • Two Motion Blur Image Units on Same Layer – PROBLEM
    Posted by Scot Walker on June 17, 2005 at 8:55 pm
    I have this Layer that has several objects in it creating a cartoon courier bag. I animate it in using key frames and the Motion Blur Image Unit. It stands and talks, then it speeds off with a key frame off the stage. I have copied and pasted my 1 second Motion Blur and moved it down the timeline for when it runs off the stage. This makes the Layer disappear. Very weird. If I delete the second Motion Blur, it’s there. If I put it back, it disappears.
    Even stranger, if I move the second 1 second Motion Blur towards the beginning, it doesn’t make the layer disappear at any point before 12:08 seconds (the object is on for 19 seconds). At any point beyond 12:08, the object disappears if I have the second Motion Blur on it.
    Any ideas?
    Scot Walker replied 21 years, 2 months ago 1 Member · 1 Reply
  • Scot Walker
    June 17, 2005 at 9:00 pm
    I changed the second Motion Blur Image Unit to a Direction Blur Filter and it solved my problem.
