Activity › Forums › Adobe Premiere Pro › Two issues, drag and drop to import / milky renders
  • Two issues, drag and drop to import / milky renders
    Posted by Mark Palmos on August 24, 2011 at 7:19 pm
    Hi guys,
    I have noticed I cannot drag and drop a file (jpeg, mpeg, mov etc) from a windows folder to my project panel. I am convinced I used to be able to do that and am wondering if I have some weird thing going on. Concurrently, I get a security check from windows when I try to run AE, it says do I want to run it as administrator.
    Second thing, is all my WMV and MOV renders are milky. Blacks are not black. I cannot see any setting to rectify that, anyone experience that too, or have excellent wmv renders?
    Your input much appreciated!
    tx
    Mark.
    Mark Palmos replied 15 years, 1 month ago 1 Member · 1 Reply
  • Mark Palmos
    August 27, 2011 at 10:34 am
    1/ the no drag and drop thing was because I had set premiere.exe and after effects.exe to be run as administrator. I disabled that and drag and drop works fine.
    2/ milkiness is vlc player, not the actual render. the render is not milky playing back with windows media player.
    user error in both cases, ahem!
    Mark.
