Activity › Forums › Apple Final Cut Pro Legacy › Two frame offset when exporting…
  • Two frame offset when exporting…
    Posted by Kenzo Kusanagi on December 1, 2009 at 3:08 pm
    Hi to everyone!
    I’m working with a project that is being captured ‘wild’ (i.e. without RS-422 control and no TimeCode signal) from a Shadow Telecine via an Aaton Keylink HD. It has TimeCode, Footage Counter and Frame Counter burnt-in.
    I’m working in Apple ProRes 422(HQ) with an AJA ioHD. My project is setup as a 24PsF project.
    When I set an in-point and an out-point in the clip (or in a Sequence) and then proceed to export it as a QuickTime Movie (same settings as project and timeline) the resulting QuickTime file has always an offset of two frames after the points I set. This happens when I export directly from the trimmed clip in the project window or from the Sequence timeline with and in-out range defined.
    For example: I set an in-point where the burnt-in TimeCode shows 01:00:00:00 and an out point at 01:24:00:00, the exported QuickTime will start with a frame where the burnt-in TC shows 01:00:00:02 and will finish with a frame where the burnt-in TC shows 01:24:00:02.
    One curious thing I’ve noticed is that, when I trim in a sequence, when the Canvas is showing me that I’m at point 01:00:00:00 the little thumbnail at the beginning of the clip in the timeline shows an image that is two frames later from what I see in the Canvas. If I ‘pull’ the in-point two frames earlier even though the canvas is showing me a different frame, in the thumbnail in the timeline I see the right frame and when I export then the resulting QuickTime begins at the right frame.
    Is this a bug?
    Best Regards,
    K
    MacPro 3,1
    2x Quad-Core Intel Xeon@2.8GHz
    4GB RAM
    3TB Internal RAID
    16TB Ciprico MV5116
    FCP 7.0.1
    Omar Khalifa replied 16 years, 6 months ago 3 Members · 2 Replies
  • Josh Olenslager
    December 3, 2009 at 4:30 am
    It sounds like a drop frame / non-drop frame issue you’re seeing. I’d check that in your sequence setting window — willing to bet that is what you’re seeing. I haven’t worked with 24psf much, but I know it reacts differently than 24p.
    Hope this helps!
    Josh Olenslager
    working on better ways to video
  • Omar Khalifa
    March 12, 2010 at 7:42 am
    Hey there! Did you solve your issue?
    I’m having exactly the same symptoms, but my issue is not just a few frames it’s minutes!
    Would value your help!
    Best,
    O
