Activity Forums Apple Final Cut Pro Two files from one
  • Two files from one
    Posted by Ed Johnson on May 22, 2015 at 11:50 pm
    I have a two hour project all finished, and now I wish to make a twenty minute summary from it. What is the correct procedure to follow so that I do not lose my two hour version, but then I can also edit a copy.
    TIA.
    Ed.
    Ed Johnson replied 11 years, 3 months ago 3 Members · 3 Replies
  • Oliver Peters
    May 23, 2015 at 12:23 am
    [ed johnson] “What is the correct procedure to follow so that I do not lose my two hour version”
    Right-click the project in the browser and select “Duplicate as Snapshot”. This will create a copy without dependencies to the first project. You can freely edit each one without affecting the other. This command is analogous to “save a copy as” in other types of applications.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Bret Williams
    May 23, 2015 at 1:36 am
    After effects should have this function. And if I’ve missed it, where is it?
  • Ed Johnson
    May 23, 2015 at 3:35 am
    Boy, what would I do without this forum!
    Thanks for saving me at least an hour and a whole bunch of stress!
