Activity › Forums › Apple Final Cut Pro › Two edit questions
  • Two edit questions
    Posted by Oliver Peters on February 17, 2013 at 12:58 am
    I don’t seem to find anyway to do these two functions in X. Are they there?
    1. A true replace edit using the playhead as a sync point. In most NLEs you would mark the timeline in/out and park the playhead on the sync point. In the source clip, you would have no marks and park the playhead on a corresponding sync point. Any way to do this in X? A typical example is to add a SFX to match a visual cue. Or when eye-matching a replacement shot.
    2. Three-point edits where the out-point of the source matches the out-point of the timeline and the in-point of the source is left blank and is automatically determined by the in-point of the timeline.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Jeremy Garchow replied 13 years, 7 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    February 17, 2013 at 4:28 am
    1) Still not there. I still miss it.
    2) “Replace from end”. It’s a command you have to assign manually, but it is there.
  • Mark Morache
    February 17, 2013 at 7:57 am
    Shift – D, and Shift – Q work just fine for #2, and like Jeremy said, you can map the Replace from end.
    I too miss the old replace.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • Oliver Peters
    February 17, 2013 at 5:54 pm
    Shift! Ah, yes, I forgot. Thanks.
    Regarding sync’ed replace edits, the only workaround I’ve found is to place the two in-points at the source and timeline frames to sync, make the edit and then trim back to fill the missing front portion of the clip before the sync point.
    – Oliver
    Orlando, FL
  • Jeremy Garchow
    February 18, 2013 at 3:52 am
    [Mark Morache] “Shift – D, and Shift – Q work just fine for #2,”
    [Oliver Peters] “Shift! Ah, yes, I forgot. Thanks.”
    It is true, shift-d does work, but it is storyline only (primary or selected secondary).
    Shift-q, obviously, adds another back timed connected clip.
    Replace from end will replace any selected clip pretty much anywhere, except it doesn’t work on a range of a clip.
    I find that all of these methods have better times to use than others, although throwing in a connected clip at any time is pretty easy to manage.
