Activity Forums Apple Final Cut Pro Legacy Two displays problem
  • Two displays problem
    Posted by Marcosh on January 30, 2013 at 8:10 pm
    Hi everyone,
    So, I have a Mac Pro, running 10.8.2, and FCP 7.0.3. In the machine I have 2 graphics cards, an ATI Radeon HD 5770 and a NVIDIA Quadro 4000. I have an Apple LCD display connected to the Radeon as my primary monitor. From the Quadro, via HDMI, I have a NEC 1920×1080 that I want to use as my second monitor. The problem is… it’s not working!
    I’m trying to monitor an Apple Pro Res 23.98 HQ project and when I choose “Show all Frames” from the video preview option, I see only a freeze frame. I tried also connecting it via VGA and the same problem occurs. I tried setting up a basic NTSC, 29.97 project and monitoring it but the same think happens.
    Now, if I have this second display hooked to the ATI Radeon card, via VGA, it works fine… but every once in a while the display “blinks” and goes white. Eventually FCP crashes.
    Nvidia people say I shouldn’t have two cards hooked to the same motherboard. I think that’s BS for i’ve been reading about people using both with no problem.
    I would really appreciate your help!!!
    Marcos H.
    Mac Pro
    3.33Hhz 6-Core Intel
    12GB RAM
    10.8.1
    FCP Studio 2
    AE / PS / AI CS6
    Neil Patience replied 13 years, 7 months ago 4 Members · 4 Replies
  • Shane Ross
    January 30, 2013 at 9:16 pm
    [Marcos Horacio] “Nvidia people say I shouldn’t have two cards hooked to the same motherboard. I think that’s BS for i’ve been reading about people using both with no problem.”
    They are right. FCP doesn’t like two graphics cards. Sure, you can have the 4000 in the system for boosting RESOLVE, but you can’t have monitors connected to both and have it work properly. FCP works with one GFX card only.
    Hook both displays to that card. But you said when you did that FCP hung? Hmmm…remove the NVIDIA and see what happens then. But for monitoring full screen, you need an IO card…VIDEO capture card, not graphcis card.
    Shane
    Little Frog Post
  • Marcosh
    January 30, 2013 at 11:05 pm
    Thanks, Shane! So, I do have a Blackmagic Decklink card in a box that I can install. Do you think I should just take the ATI Radeon? Apparently Is FCP the only app which doesn’t like two graphics cards? I was using Premiere Pro and AE CS2 and, besides some eventual hickups (the second display goes blank every now and then) they ran pretty smoothly.
    Marcos H.
    Mac Pro
    12GB RAM
    10.8.1
    FCP Studio 2
    AE / PS / AI CS6
  • Steve Eisen
    January 31, 2013 at 12:08 am
    If you plan on upgrading to CS6, the Quadro 4000 will be a perfect match!
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Neil Patience
    January 31, 2013 at 12:15 am
    [Marcos Horacio] “Apparently Is FCP the only app which doesn’t like two graphics cards?”
    Of course it is long in the tooth now but Apple Color also will not run with 2 video cards
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
