Activity Forums Apple Final Cut Pro Legacy two computers hooked up to one eSata drive
  • two computers hooked up to one eSata drive
    Posted by Jason Szabo on May 12, 2008 at 2:55 pm
    Working on a macpro, 8 core,10.5.2
    Wondering if I could safely hook up a macbook pro, via ethernet, to the macpro and share the eSata drive (g-raid).
    I’m exporting uncompressed quicktimes, DVCproHD 1080i60, for my color correct. They’re about 4 minutes each (total exported qt size is 48gigs).
    Its taking about half an hour each quicktime and I’d like to work while I export. Can I use the macbookpro to handle the exports while I work on the tower?
    thanks,
    Jay
    Jason Szabo
    Jeff Carpenter replied 18 years, 4 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    May 12, 2008 at 4:10 pm
    Yes you could do that as long as you have two licenses for the studio…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Russell Lasson
    May 12, 2008 at 4:14 pm
    Sharing video media over basic Apple file sharing isn’t as reliable as using a SAN. You can try it, but it’s possible to do. I’ve done things like that when I’ve been sort on equipment, but I don’t suggest it as an everyday solution.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Jason Szabo
    May 12, 2008 at 4:54 pm
    Thanks for the advice guys.
    Jason Szabo
  • Jeff Carpenter
    May 12, 2008 at 5:48 pm
    I’ve done this lots of times with DV footage and HD Apple Intermediate Codec. I was using a firewire 800 drive instead of eSATA, but it’s the same idea. Always worked fine for me.
    Just make sure that ALL parts of the network (such as the router) give you gigabit speed. Test your network by copying a large file from one computer to the other. You should be getting close to 1 GB per minute. If you’re not, something’s getting in the way and preventing you from getting full speed on the network. You can check that out right now with any file.
    Also, the “2 copies of Final Cut” isn’t one of those things about how “it’s the right thing.” No, this one’s for real. The second copy literally won’t launch unless it has its own serial number.
