Activity Forums Adobe After Effects Twixtor working only with positive speed values, not negative
  • Twixtor working only with positive speed values, not negative
    Posted by James Harris on February 16, 2017 at 8:56 am
    Never had this but when I am tryong to apply Twixtor to my sequence it only works if the speed % is set to a positive value.
    If I set it to something like -10 and hit play nothing happens and if I hit the preview ram button I get this error message:
    “After Effects error: RAM Preview needs 2 or more frames to playback”
    Any ideas on how to fix this problem?
    James Harris replied 9 years, 6 months ago 1 Member · 2 Replies
  • James Harris
    February 17, 2017 at 8:14 pm
    Hey Dave,
    The last I used AE and twixtor was 7 years ago so forgot a few details, picking up things again.
    I don’t want to animate the speed of a clip I just want to slow it down (constant speed) in an elegant way without it being clunky.
    I don’t like to use the native time remapping tool in AE because the slow motion effect is never as smooth and fluid as in twixtor, this is why I chose twixtor.
  • James Harris
    February 18, 2017 at 7:38 pm
    OK, to sum things up if one wants to have a nice slow motion effect here are the options:
    1-convert from 60fps to 30fps + enable frame blending or use RS motion blur or use timewarp motion blur.
    2-use time strech + enable frame blending or RS motion blur or time warp motion blur.
    3-use simple time warp (enable built in blending).
    4-use twixtor (enable built in blending).
    PLZ corerct if I am wrong.
