Activity Forums Adobe After Effects Twixtor the Un-Twixtorable?
  • Twixtor the Un-Twixtorable?
    Posted by Adam Koubek on November 17, 2012 at 4:43 pm
    This is the shot I have to work with. For obvious reasons, twixtor doesn’t like it. My thoughts are that I can mask out the runner then render him out (because I’m pretty sure Twixtor ignores masks), then place him back on a clean plate of the surroundings I have. I will also isolate the bottom part and twixtor that on its own then match with the masked footage. My question, is this a logical solution? Any tips? Is there a better way to get around this? I’ve already started the roto process but for obvious reasons, I’d like to make sure my planned method will work before I spend a few more hours on roto. The footage was shot with a Red Epic at a high frame rate so the fence is the only problem.
    -Nack-
    Adam Koubek replied 13 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
