Activity › Forums › Adobe After Effects › Twixtor SHIFTS video. Desired in out point inaccessible.
  • Jamie Wonnacott
    November 20, 2013 at 11:44 pm
    Gentlemen,
    Thanks for taking the time to reply and confirming my understanding about Twixtor working reference the first frame. In future I will tried your methods.
    I had a second look prior to discovering your replies and came up with the following workaround:
    1. Copied the complete composition from PP to AE and then applied the following procedure to each layer:
    2. Duplicate layer, return Speed to 100%, Enable Time-remapping, Apply Twixtor and set Speed (which, as you say, is equal to original speed in PP or Inverse Speed in AE).
    NOW TO RESYNC FOOTAGE
    3. Align the first Time-Remapping keyframe (of the copied layer) with the first frame of the layer below (the original).
    4. Trim the IN and OUT points to match the original layer below.
    5. Turn the uppermost layer on and off to check synchronisation with the original layer (you notice small changes where Twixtor has interpolated data). Once Checked delete the original layer.
    It’s not pretty but it worked in the circumstances. Plus knowing your keyboard shortcuts made the process fairly quick.
    It’s a shame that Twixtor works by having to enter a speed into the plugin settings and not just interpolating speeds/time-remapping within each layer.
    Thanks again for your input. Always great to know the community is alive and so willing to help. The very best to you all.
    Jamie Wonnacott
    Creative Video Production Bristol Somerset
    Wedding Video Production Somerset
Page 2 of 2
