Activity › Forums › RE:Vision Effects › Twixtor Plugin with Sounds
  • Twixtor Plugin with Sounds
    Posted by David Ancerys on July 11, 2010 at 12:48 pm
    Hello everyone once again 🙂
    I had basic question is there a way to twixtor sound?
    I know that twixtor plugin is for video editing but is there a way to manipulate that to make sound sync well perfectly with video?? Or it must be done manually?
    Thank you. David
    Pierre Jasmin replied 16 years, 2 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    July 11, 2010 at 11:30 pm
    Try the lip-synch tutorials (there is one for AE, Premiere and FCP)
    https://library.creativecow.net/tutorials/revisionfx
    There is also the option in AE to duplicate the audio track as a separate layer, and animate the audio with AE time remapping. If you work in Frame mode in Twixtor then you can cut and paste the keyframe values you made to timeremap the audio into Twixtor Frame parameter. AE will try to maintain the audio pitch level.
    Pierre
