Activity › Forums › Adobe After Effects › Twixtor plugin for FCPX pausing on and off
  • Twixtor plugin for FCPX pausing on and off
    Posted by Ryan Spaulding on February 23, 2014 at 1:57 am
    I’m trying to experiment with Twixtor plugin for FCPX and I am seeing the ‘twixtored’ video pause every second or so even when fully rendered.
    Video: 60p 1/4000 from a Canon T2i
    Twixtor settings: Smart blend on, slowed down to 7%, everything else set as default.
    I’ve tried letting FCPX create the project settings (which sets to 59.9f fps) and I’ve tried a new project set manually to 60 fps. I also looked frame by frame to see if there are any duplicated frames in the original video and it seemed like every frame was different.
    Let me know if you need any more info to help,
    Pierre Jasmin replied 12 years, 7 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    February 23, 2014 at 2:12 am
    Somewhere there is a FPS difference between how FCP interprets footage in and what Twixtor is asked to render
    Can you verify from around 0:45 in this tutorial if you are doing this properly – you need to set this to there is no frame duplication (or skipping) performed by FCP —
    https://help.revisionfx.com/album/28/#/tutorial-147
