Activity Forums Adobe After Effects Twixtor : multiple same frame (already tried a lot of things)
  • Twixtor : multiple same frame (already tried a lot of things)
    Posted by Eric Bechet on January 13, 2015 at 6:42 pm
    Im totally new here, i read a lot of threads here, because i started editing on SonyVegasPro 11 one year ago. They were mostly really helpfull! Two weeks ago i turned to AE Cs6, and i really like this software, even if im not an editing god.
    I am using Twixtor 5.1.0 (not 5.1.5) and when i slow a track down, the twixtor make several times the same frame, then switch to the next one : like a simply time modifier, there isn’t any created frame, so it gives something choppy. (redondant)
    I rode a lot of forums, read a lot of topics, but nothing helped me.
    Am i Blind?!
    More informations : The clip i want to slow down is at 60fps, and it’s the direct recorded file from Fraps. + input frame rate put to 60fps
    Twixtor seems to work perfectly on the same clip, just before the problem : Clip’sBegining——-Working Twixtor DESPITE ANIMATED SPEED——Freezing/duplicated frames——End of te clip.
    For me it looks really randomns :/
    And the only Twixtor setting that i change is speed.
    Hope you guys will find something :p (as i said i tried many things, but give them again, we never know :s )
    Im newbie pls dont kill me
    Eric Bechet replied 11 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
