Activity › Forums › RE:Vision Effects › Twixtor demo questions using 30p footy
Posted by Warden on November 23, 2005 at 4:53 pmSet up: Final Cut Pro HD, Canon GL2 shooting in
Warden replied 20 years, 10 months ago 3 Members · 5 Replies -
Warden
November 23, 2005 at 6:07 pmPeter,
Thanks for the quick response.
I found the manual. I guess I was just over-looking it.What you said about not needing the DeInterlacer was what I had expected. I just wanted confirmation.
I will give creating a separate matte for the foreground a shot. There are only a couple of points that are causing me trouble and may be confusing the plug-in.
Is there a way that I could send you a compressed version of the clip so you can see what I am talking about? -
Peter Litwinowicz
November 23, 2005 at 10:43 pmsure you can send along a clip. If it’s less than 5Mb, send it to techsupport@revisionfx.com.
Otherwise, perhaps you can make it available via an ftp or website?
pete -
Pierre Jasmin
November 23, 2005 at 11:42 pmYou might consider as well checking TwixtorBasics Tutorials
which you can get from here:https://www.revisionfx.com/rstwixtortutorials.htm
Pierre
Warden
November 24, 2005 at 1:36 amPeter, I trimmed the clip down to just under 2 seconds in length and compressed it to 360×240 so the file size is very small. I’ll send it to you to get your opinion on it.
Pierre, I have already went through the tutorial but I never checked out the manual. I’m doing that now. 😉
