Activity › Forums › Adobe After Effects › Twixtor crashing Premiere Pro 2014 on launch
  • Twixtor crashing Premiere Pro 2014 on launch
    Posted by Joe Bender on July 3, 2014 at 3:50 pm
    EDIT:
    Apologies for the premature post — on further testing it seems to be all my MediaCore plugins that are having problems. I’ll keep looking for fixes for that and report back if I find anything.
    Hi all —
    I’m pretty excited about some of the features in the new PPro 2014, which I decided to try out last week, but it’s crashing on launch when it tries to load Twixtor. Plugin incompatibility happens often with new software versions, so I didn’t think much of it and figured I’d continue my projects in the old version (not switching horses in mid-stream and all that) and check forums in a week to see if others encountered the same problem. Now I’m not seeing anyone else having this problem. Is there a simple fix that I’m missing?
    Thanks in advance for your help!
    Joe
    Pierre Jasmin replied 12 years, 2 months ago 2 Members · 3 Replies
  • Pierre Jasmin
    July 3, 2014 at 4:00 pm
    What is the version of Twixtor?
    How did you install it?
    What OS?
    Not clear what you say:
    Premiere is crashing on launch with a project with Twixtor in it, on application of Twixtor, just generally crash if installed when Premiere starts?
    Pierre
  • Joe Bender
    July 3, 2014 at 4:17 pm
    Thank you for your response,
    Premiere Pro 2014 crashes on launch when loading any MediaCore plugin. I’m going to try uninstall/reinstall once I’m at a place with my projects where I can take the time.
  • Pierre Jasmin
    July 5, 2014 at 12:17 am
    OK, if it still does it, you should report this to Adobe
    Pierre
