Activity › Forums › RE:Vision Effects › Twixtor 3.x really works with Premiere Pro ???
  • Twixtor 3.x really works with Premiere Pro ???
    Posted by Rampanat on February 17, 2006 at 10:11 am
    I think I’m getting paranoid !!
    I’m trying to get slow motion wiht twixtor in Premiere Pro.
    When I do that with any other filter on my footage, it seems to be all right. But if I apply “shadow/highlight” Premiere effect after twixtor(and in my particular case I need to do that), appears like a persistent and undesirable flikering every fixed frames. Seems like “Shadow/Highlight” changes one frame every number of fixed frames.
    Furthermore, If I apply twixtor after “shadow/highlight” (and not before), then “shadow/highlight” does not work, and that happens with other Premiere effects. It seems like twixtor does not let any other filter to work with it.
    First of all:
    Rampanat replied 20 years, 7 months ago 2 Members · 2 Replies
  • Pierre Jasmin
    February 17, 2006 at 6:56 pm
    You cannot apply an effect before Twixtor in Premiere unless it’s within a nested sequence, however you should be able to apply one after unless like Twixtor it’s accesses multiple frames per frame.
    To apply an effect before Twixtor:
    create a nested sequence, drop your footage in it, drop your effect there and then in the main sequence, set the color source to that nested sequence (eg video track 2 or whatever it is)
    Are you using PPRO 1.5 or 2? As well does your material have fields?
    If it’s the same Shadow/Highlight as AE (just got new PPRO 2 this week and have not installed yet), then it has a temporal smoothing option (thus accesses multiple frames somehow), therefore would probably require an additional level of nesting to work in Premiere correctly.
    Pierre
    RE:Vision Effects
    Pierre
  • Rampanat
    February 21, 2006 at 1:39 pm
    Thanks, Pierre
    I could solve the problem with the answer you suggested.
    I will have to think in nested sequences more often.
    Antonio
