Activity Forums Apple Final Cut Pro Legacy tv-out ideas + bare bones g4
  • tv-out ideas + bare bones g4
    Posted by Rick Neely on December 10, 2006 at 5:12 pm
    Hi guys,
    Just want to get a couple ideas from you experts–
    I need to get FCP 5.1 running on another mac computer for a seriously bare bones alternate workstation. So I’m looking for what inexpensive, yet functional mac computer option I should go with. No need for a g5 here. I’ll be doingf basic capture with minor effect applications. No HD, no uncompressed BetacamSP, just straight DV or DV50. I will need however a decent hard drive, at least 1 gb ram, and a superdrive to run DVDSP. Should I get a g4, or can I get away with a new Mac mini? Which is the better course of action?
    secondly, I’ll need to video preview to an NTSC monitor. Once again, minimal cost here. Don’t need to utilize an AJA IO or similar capture box (again all capture will be via firewire). I just need to see a decent NTSC preview for Final Cut. Is there a recommended good Video card with a TV OUT someone can recommend, or another option. Is there a way to trick the DVI-OUT to feed a FCP sequence preview to an NTSC monitor with a special cable? Willing to think outside the box.
    Thanks Again. Happy Holidays!
    13 replied 19 years, 9 months ago 3 Members · 2 Replies
  • Kevin Monahan
    December 10, 2006 at 6:02 pm
    You can probably find a used G4 with a SuperDrive. That would be fine.
    Don’t get a Mini, go for an iMac at a minimum if you want a newer Mac.
    Video monitoring can be done passing through a DV Camcorder, as usual.
    You can also use the Pyro AV or the Canopus ADVC700 DV transcode devices.
    Video display cards are typically not used for monitoring with FCP and that’s been since FCP 1.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • 13 Create COW Profile Image
    13
    December 10, 2006 at 7:21 pm
    I would look into an iMac
