Activity › Forums › Adobe Audition › Tutorials in performing audio ‘surgery’, fixing dialogue
Posted by Jim Bachalo on June 13, 2014 at 12:19 pmCan anyone point me to tutorials for Audition in performing audio ‘surgery’, fixing dialogue etc. In the wave editor, I need to be able to splice specific parts of dialogue so the match is totally seamless.
Joseph W. bourke replied 12 years, 3 months ago 2 Members · 3 Replies -
Joseph W. bourke
June 17, 2014 at 6:33 pmIn terms of just slicing and dicing, removing breaths, etc., I simply zoom in on the VO, then go through it section by section, using the Insert Silence command on the selected breath (works on background noise as well, or page noise). The best tip I can give you is to zoom in tight, so you can really see the waveform, and take out awkward pauses (I just select a bit of silence, then hit Delete).
Here’s a good tutorial on processing the VO to make it sound great after you’ve got your cleanup and timing done:
https://www.youtube.com/watch?v=JOfL_75OqpY
I also leave the Auto Heal feature turned on, so if I cut something out, or add something in, it helps it to sound natural:
https://tv.adobe.com/watch/peachpit-tv-for-video/healing-audio/
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jim Bachalo
June 17, 2014 at 7:01 pmThanks!
Ended up going thru the Lynda.com course. Picked up a few tips, like first adjusting the zero crossing, taking advantage of the multiple clipboards feature, etc.
One feature I’ve always found a bit confusing is how to apply effects, AND save them in case you want to reopen the file at another time.
Even though there is an Effects rack available in the wave editor, once you apply the effects, they are gone.
My understanding is that you MUSt create a multitrack session, and then use the effects there if you want to reopen at another time, and change the effects previously applied.
You should follow me on Twitter here. My latest work
Joseph W. bourke
June 17, 2014 at 10:13 pmJim –
You know you can save Effects Presets, just like in other Adobe software? You can also assign them to a hot key. Here’s a short tutorial:
https://www.youtube.com/watch?v=Tpvf1L7qnsg
Joe Bourke
Bourke Media
