Activity › Forums › Adobe After Effects › Tutorial: Makin’ An Eclipse
Posted by Graham Quince on August 21, 2020 at 6:01 pmGraham Quince replied 5 years, 6 months ago 2 Members · 2 Replies -
José Moreira
February 5, 2021 at 2:43 pmHello Graham Quince.
I saw on the foruns that advice very well some feactures which can generate some doubts in after effects.
I´ m a beginner in after effects having the basics and the intermediate Knowledge in this program. So i ´ m following an tutorial to improve my skills and to feel more confortable with this program because the course that i took i didn t learn this program more dephly.
I have a doubt to clarify that is:
Which steps do you do to copy and paste the x, y and z rotation of a scene 1 comp to a scene 2 as the image?
My problem is that is scene 1 show up only the “Rotation” not the x,y and z rotation options of the scene 2.
I will be grateful for your support.
I exepect your answer as soon as possible.
Best regards
José Moreira
Graham Quince
February 6, 2021 at 10:27 amHi José
Unfortunately the image you posted doesn’t appear – so I can’t easily see the issue. But if I understand your question, you can only see the Rotation property of the layer, not the X,Y,Z rotation values.
That suggests to me that the layer is a 2D layer. You need to make it 3D in order to see the three rotation values.
