Activity › Forums › Adobe Photoshop › Tutorial for open wooden window frame
  • Tutorial for open wooden window frame
    Posted by Dave Du plessis on August 16, 2016 at 6:35 pm
    Good day …. in my search for a tutorial that lasts for weeks, I came across this site and joined because I know I will find what I was looking for. I would very much like a tutorial to build an open wooden window frame with Photoshop. I use PS CC2015 and the window must be actual window size to make a fake window so a picture can be placed behind it. I’d like it to be in multi (at least two) panes (windows opening to left and right). Thanks in advance:-)
    Dave Du plessis replied 10 years, 1 month ago 2 Members · 3 Replies
  • Dave Du plessis
    August 16, 2016 at 8:26 pm
    In follow-up to my question, here is a perfect example of what I would like to build in PSD.
    In fact, I would like to be able to build the same frame in Photoshop.
    https://www.toperfect.com/View-of-Paradise-magic-3D.html
  • Kalleheikki Kannisto
    August 16, 2016 at 9:02 pm
    You could use Filter Forge to create wooden frame pieces to the size you want and combine them in Photoshop in flat view, then pespective distort the two sides to make them look like the windows are open.
    Here’s a nice wooden frame filter: https://www.filterforge.com/filters/11740-v5.html
    Filter Forge is commercial, but there’s a 30-day free trial with up to 3000×3000 pixel rendering capability.
    Senior Graphic Designer
  • Dave Du plessis
    August 16, 2016 at 9:08 pm
    Wish I joined here longer ago! Thank you for the prompt reply, Kalle. 🙂
