Turning an Map image into 3D in Vegas
John Rofrano replied 16 years, 8 months ago 3 Members · 23 Replies
John Rofrano
January 12, 2010 at 12:40 amReferring to the screen capture your video is not broadcast safe because it exceeds 100. Considering that it is a solid line on the right side of the waveform I’m guessing that it’s your logo. See here:
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Don Kimball
January 12, 2010 at 2:50 amHi John: I chose the setting Lenient 7.5 setup and applied it to the entire video track. Here is what it looked like in the wafeform monitor. Is this still too unsafe? By the way the Map on the video is going to be about only 20 percent of this size when completed. I am wondering if that will change the broadcast safe settings… hmm..
Thanks for you help! New territory for me for sure and one I need to learn.
Don
http://www.polytelismedia.wordpress.com
John Rofrano
January 12, 2010 at 3:07 amApply it to the video output. You still have values over 100 on the waveform monitor.
~jr
