Activity Forums Adobe After Effects turning AE into an image sequence auto-loader.
  • turning AE into an image sequence auto-loader.
    Posted by Rich Ramazinski on October 30, 2006 at 7:26 pm
    Ladies and Gentlemen-
    I have a situation where i need image sequences to be rendered out asap, as source folders get filled up with images.
    With AE, i have to select the sequence in each folder, put the sequence into a comp, and then i have a render preset made to dump out a quicktime in the format i’d like. To do the next sequence, I have to select the next folder, etc etc etc.
    Ideally, i’d like an even more automated way of doing this. Before I hop on the scripting train, does anybody know of an easier way in AE, or of a different program, that would achieve this goal?
    Rich
    Aharon Rabinowitz replied 19 years, 10 months ago 2 Members · 1 Reply
  • Aharon Rabinowitz
    October 31, 2006 at 12:42 am
    Drag the folders from windows explorer (or Mac Finder) into the project pannel. You must drage the folders containing the image sequence. It can;t be a folder containing a folders with image sequences.
    this will import all images in each folder as an image sequences.*
    Next, drop all of the imported sequences into the render queue – this will automatically create a comp for each sequence that is already set up in the render queue.
    * (this assumes your AE import preferences are set to the defualt of importing folders as sequences. If you;ve tamplered with this, or it;s not working, go into the import preferences and change this. I am not infront of AE, and I can;t remember the preference name.)
    I think this will make a good workflow podcast…
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
