Activity › Forums › Adobe After Effects › TURN OFF automatically converting images into image sequence
  • TURN OFF automatically converting images into image sequence
    Posted by Christian Simpson on August 4, 2017 at 7:55 pm
    Every time I try and import an image into After Effects it automatically converts it into an image sequence. I know why it’s doing it because our files are labeled ex. newton_cam_001.psd and newton_cam_002.psd but does anyone know how I can prevent after effects from automatically making an image sequence. I do not want it to do that. We cannot change the file naming format for our pieces of media before you ask and we cannot store different pieces in different folders.
    Steve Bentley replied 9 years, 1 month ago 3 Members · 3 Replies
  • Christian Simpson
    August 4, 2017 at 8:25 pm
    There is not unfortunately.
  • Jeff Hinkle
    August 4, 2017 at 9:10 pm
    On the Import dialog box, click Options then uncheck “import as sequence.” Not terribly automatic, but it’ll let you import individual files.
    It is easier to destroy than to create.
    More fun, too.
  • Steve Bentley
    August 4, 2017 at 11:05 pm
    And I think it stays the way its set so the next time you import it should be set. You just have to remember to turn it back on when you want a sequence again
