Activity Forums Adobe After Effects Turn object filmed rotating on turntable in green box into the virtual camera movement around the object
  • Turn object filmed rotating on turntable in green box into the virtual camera movement around the object
    Posted by Muaz Nikolic on October 4, 2016 at 1:35 pm
    Hello,
    I am trying to the following thing; I want to record an object rotating on the turntable and from that to get the virtual camera movement as if the camera was moving around that object.
    I filmed the object on turntable rotating in the green screen and placed the tracking points around the turntable so I could be able to track the movement. When I 3D track the footage in AE I am not able to solve the 3D camera, when I tracked the footage in Cinema 4D instead of circle movement I get the spiral movement and the virtual camera movement is not correct.
    I hope that someone could help me how to solve this problem or give me any guidance how am I going to be able to make idea work. Thank you all in advance.
    Muaz Nikolic replied 9 years, 11 months ago 1 Member · 1 Reply
  • Muaz Nikolic
    October 5, 2016 at 9:42 am
    Thank you Dave,
    sometimes simple solutions are the best solutions. I tried to solve my problem by complicating it to much (tracking the video). Thanks again.
