Activity Forums Adobe After Effects Expressions Turn Expressions into keyframes BUG in CC 2017
  • Turn Expressions into keyframes BUG in CC 2017
    Posted by Arturo Moreno reyes on August 29, 2017 at 3:09 pm
    Hi, I’ve made an expressions using sampleImage to do a levels automatically, in CS6 and older I used to turn expression into keyframes so I was able to copy the Levels Effect into other rushes, but since I’m in CC 2017 all the values change when I try to turn them in expressions. It works fine if I do it prperty by property but if I choose the whole chunk numbers are just wierd.
    Does anybudy know why that’s it, and how to solve it?
    Arturo Moreno reyes replied 9 years ago 1 Member · 0 Replies
  • 0 Replies
